T&D Roller Rocker Problem .Help !
KWIKR 1
Picked up a set of T&D roller rockers off the board . Upon taking them apart for cleaning and inspection . I found that on one rocker the oil passage that feeds the valve stem roller tip is "NOT" drilled all the way thru . meaning a oil supply to the roller tip will not be avaiable if the rocker was put in service . being the way it is , it is imposible to drill it out with the roller tip being in the way . what are my options ????????? thanks .
Call the guys at T&D. They'll likely just send you a new rocker.
yeah.... I'm thinking of packing it up and shipping it off with a note to T&D Machine . Nothing ever goes right with these things . I'm just glad I caught it . I'm not sure how much oil the roller tip needs or actually gets from this oil feed passage , but I would like to think it needs something . :)
