T-type in Louisville ky
sowle
Over crist-day weekend I pulled down my 83 turbo from Iowa. Thought I would post it here first before I put it on the street. Asking 1,700, I will give more details when I get time. Many new parts much work has been done. Many extra parts go with, for it is for the collector. ;)
Two extra turbos with upper plenums. One extra carb. Extra nose header panel. New windshield. 86-87 T-type wheels. 86 block crank & rods, Overhauled not rebuilt meaning unturned crank- standard bore cylinders- nothing machined. Origional pistons to the block, replaced rings & bearings. Untouched origional heads to the car- smokes on startup. Extra charcoal canister. Car has aluminum bumper braces, aluminum drums. Leir Zeigler buckets column shift. Extra grill. There's more
Spare ECM, new head lights, recently reworked alternator. Just serviced the tranny[filter change] and a new fuel pump. Extra down pipe. Spare hydroboost assembly- mc & power steering pump & lines included. Rear end serviced with new pinion seal and axle seals. Brakes are all pretty fresh. Extra headlight bezels. Shocks are also pretty fresh.
