T.V. Cable ALL the way out??????
TRYMYSIX
Ok...I was looking at my T.V. cable as I was going to adjust it to make sure everything is right. I counted the rings before adjustment, count 6 rings showing......So I pulled the cable back to the firewall, pressed the gas pedal to WOT and I only heard one ratchet click before WOT. I go look at the rings, now I see 6 rings showing + 1/8" of cable housing showing..So basically I'm out of rings...........Is this right?
Press half moon tab and pull cable toward firewall. Then grab throttle and go WOT and it will ratchet out..click. The TV bracket should flex some at WOT when adjusted correctly. you only have about 2 maybe 3 clicks out from there and then shifts soften and thats bad ju ju.
Go WOT at the TB with your hand and watch the TV cable.
Pick the brains of the TR guys around there they know whats up.
It's possible your TV cable is stretched, and for the cheap cost of replacing the TV cable is better then to replace the tranny for incorrect adjustment.
