my Ta33 spooled like the stocker did with stock stall convertor. I not have a 2800 stall and intercooler setup. the lag is minimal, nothing that would really hurt me. but when max boost hits, watch out, im flying!
Maybe it could be your exhaust leak doing it. Also check all your vac lines running to the wastegate and solenoid. also make sure the puck is sealing correctly. How much boost are you currently running? how were the adapter seals and such? there could be a fre reasons for this problem, if u coiuld tell us more we will 4 sho try to help you!
ended up being a huge crack all the way around the #2 manifold primary but yeah my car pull like crazy on the top end now picked up 4 mph with less than 2 psi.
