ta 49 needs rebuild
ROBERT HAYDEN
my ta 49 is dumping oil into the maf pipe and inncooler,anyone know of somebody who can rebuild it or if their is a rebuild kit available in or near maryland,..thanks
Send it to Limited turn around time is quick and there are different
options to ship. Just don't use Post Office unless you can afford to wait a long time.
Limited also sells a rebuild kit.
you can rebuild it yourself, depending on your mechanic abilities. Go to a local turbo shop they might have a seal kit or be able to order one for you. Do a search, lots of info on this topic...:D
what is limited?,i've tried the so called local turbo shops in my area,they have no clue how to rebuild one,but they will gladly sell me a new one....,i took it apart,and put it right back together!,it doesn't seen to hard to put a seal kit in,just need one,thanks
Limit Enginering -John Craig- 1-928-453-7321
Still thinking about heading to OC next thursday?
later-Kurt
turbo rebuild
Yeah, go with John Craig @ limit, had my 62 rebuilt there & it was worth it. Great people to work with...
No, I just sent the turbo to them...depending on your problem, a rebuild usually requires the use of a balancing machine for the turbo. I have little experience with rebuilds, hence sending it to limited, it was the best thing I did. Give them a call and they will give you a little more insight. Great people to work with!
