SignUp Now!flattype said:A te44 is bigger than a ta49 right?
1QUICK85 said:Never realized that the ta49 wasn't that much better then a stock 86/87 turbo, like is being discussed here. So, if the stocker is very close to the ta49, do you need to run bigger injectors then the stock 28#'ers?? I picked up 40#ers when I bought my turbo, because I was told I would need more injector? Are they just needed to run the higher boost levels......above 20#'s?
TIA, Nick.
