Ta 60 or Te60
jbohrer8
I am going to upgrade my turbo but would like to have some opinions whether to get a te 60 or a ta 60. I really do not care whether i stay stock appearing or not. I have a 3300 stall converter and the stock turbo just aint cutting it. i have 36# injectors for now. and am ready to move up from the stock turbo.
any help would be greatly appreciated,
thanks
John
How fast do you want to go? If you don't race your car that often I would recommend a Limit GT6152, pulls really hard down low to the lower 20's on boost. I ran mine for a while on a stock motor and loved the "pull" it had. If you race it often I would skip the TE60 and go for a TE61, a few on this board have pushed well into the 11's with stock heads and high boost 25+#, you have the stall for it...might want to upgrade injectors with the bigger turbo.
car is my daily driver, so i have to keep that in mind. I am a college student so i dont have too much money to spend. but i want to make my gn go faster!!!
TA60 you will love it, rocks right off the line and pull pretty good through the whole range..also very good turbo had mine for over 4 yrs not a problem with it.
*Chopper* at Limited Eng, said there was less then 3% difference between the two. IMO, it's worth *risking* as much as 3%, to be stock looking.
