87we410877
- Apr 5, 2005
I have a used TA-62 turbo that needs re-building and a new compressor blade. The anti freeze got into the the bearings, causes loss of lubrication to the bearings, and allowed the compressor wheel to scrape the sides of the compressor housing. The housing doesnt look bad at all but you can see the scores and nicks in the blade. New bearings are a must. The exhaust side is Ceramic coated by performance coatings. Cant say much for them but its better than all rust, the center section is hi temp black and the compressor is hand polished on the top. The exhaust is a/r .63 and is Garrett and the compressor is a/r .60 and is Precision. The compressor blade is 62mm. 3 bolt flange for the header and im not sure which type of set up the exhaust is called but i had an external wastegate. 4 bolt DP set up. Im open to offers.
