- May 25, 2001
I've been mulling over and waffling back and forth on what I want to do with this car. My car will never be a show car so I might as well do what I really want with it. I am stuck in So-Cal for another 8-9 years so as of right now all my racing will be 1/8 mile unless I take it to Vegas or Phoenix.
Is a TA-6262 DBB enough turbo to push a average weight TR (solid roof, power accessories) to 6.50-6.60 in the 1/8th (low 10s?) or should I be looking at something a bit bigger?
The turbo is currently boxed up and ready to send back to PTE because of this thread: http://turbobuick.com/forums/thread...-this-noise-down-to-the-downpipe-puck.377863/ My smokey stock turbo was quiet so it is an issue in that turbo. On a side note, I can now swap turbos in about 15 min
- I know the TA housing is going to be a restriction. I am not against going to a TE style anymore, but if I can keep the current turbo, great.
- I will probably have to run race gas to do it. 24ish PSI on 91/Alky might not be enough.
- The short block already has steel caps and TRW forged pistons.
- The converter is currently a 3200 stall N/L 9.5".
- I assume I might need better heads and cam than what I have. The heads have bigger valves and port work done behind them but just light cleanup otherwise. I would love to go with GN1's but the lack of EGR makes it even harder to smog the car here in CA.
- The cam is odd, details are in another thread. (http://turbobuick.com/forums/threads/cam-question.377940/)
