TA perf Alum Stage 2 long block $9800!!!
turbobuick
Staff member
I need this gone.
http://www.turbobuick.com/forums/threads/ta-performance-alum-s2-motor-complete.399377/
This is a running motor with break in time only. Fresh ready to go!!!
Selling as long block only. No accessories, front cover or oil pan balancer or flexplate. I will include motor mounts, valve covers and intake manifold with dual fuel rails. No injectors, throttle body plenum regulator etc that are in the pictures.
I can have it at Norwalk Sept 8 or can ship R&L freight.
Everything is in the link above. If you need any more info PM me.
Short block is sold.
Still available:
On Center intake with dual fuel rails $450 Fuel lines and fittings including Y block $75
Wilson 90mm TB and plenum with throttle cable bracket $200
160# injectors $300
83# injectors $200
Meziere hi flow water pump $325
Moroso 4 vane vacuum pump with pulley $400
140 amp Alt with adj voltage regulator $85
Moroso flying magnet crank trigger custom setup for a Buick V6 with XFI $175
Stage 2 heads with titanium intake inconel exh valves. ALL parts are new fresh this is a bolt on and go set of heads needs nothing None of the parts were used prior to these heads being built. Complete with Jesel rockers and valve covers. $1500
Weldon 2040 fuel pressure regulator $200
I am sure I will have more by the time I get to Norwalk with this stuff.
Yes, I am probably parting out my Drag Radial car. I will have a complete motor with belt drive and all the supporting stuff to go with. I am waiting to see what happens with the roller first. LMK if you will be interested.
Interested in your Stage II parts.
Mike
