Mar 12, 2014 #1 T turboclam Well-Known Member Joined Sep 30, 2003 Messages 2,109 What do you think of these numbers. There's room for improvement but is it worth it? Can I run a high 9? This is TA's stage 2 port work. Attachments image.jpg 3 MB · Views: 147
Mar 12, 2014 #2 jpwalt1987 Well-Known Member Joined Nov 9, 2003 Messages 1,885 Just for comparisons sake my GN1 heads flow 249 intake and 200 exhaust@.550 Posted from the TurboBuick.Com mobile app
Mar 12, 2014 #3 J johnplogii Senior citizen Joined Aug 13, 2005 Messages 1,978 The low lift intake #'s sure look low. Anyways 230 cfm is good for mid-high 8's in my opinion.
Mar 12, 2014 #4 S Sydwyndr Admin Staff member Joined May 25, 2001 Messages 3,547 turboclam said: What do you think of these numbers. There's room for improvement but is it worth it? Can I run a high 9? This is TA's stage 2 port work. Click to expand... You can run high 9s with the proper setup such as cam, heads, turbo, converter...... Everything needs to work in unison for the most efficiency....
Mar 12, 2014 #5 BEATAV8 The Engine Whisperer TurboBuick.Com Supporter! Joined Feb 14, 2002 Messages 5,864 My GN1's are posted here on page 4: http://www.turbobuick.com/forums/threads/gn1-rs-ported-unported-stock-heads.216319/page-4 Car weighs about 3900 with me in it. traps 132mph with 27psi.
