ta49, 2 1/2 downpipe, cold air kit
Thumper
slightly used ta 49 with garrett ex housing, no actuator or inlet bell, with a mere 293 exact miles. asking $550 shipped
used copy of a atr downpipe 2 1/2 inch that bolts to the stock elbow, stainless steel nice $100
a new cold air kit, 3" and for a TE STYLE turbo that has everything from the turbo to down below the headlight area going thru the radiator support with the exception of the maf sensor and air filter. May be able to get a new S&B if needed but will cost more. $175 This is 3" between maf and turbo, 4" from maf thru rad support.
used black original gm headlight metal rings to hold the headlight in the bucket, set of four, may need fresh paint to suit you? $20 shipped
original stereo wires with aftermarket radio adapter wires conected together, for those looking to correct cut out and missing radio wires. $20
used gn wheel center caps, driver cond $10 each
factory spark plug plastic wire loom holders, enough to do a complete car to fact. setup. $7.00 set
used 87 chrome grille, 1 small crack in top area $50 shipped
used 87 limited NA passenger side lighted trim peice over glove box
make offer?
stock crank pully and bolts $40
more items to come.......
email me to get pics billthomp86@yahoo.com
Bill
plug wire holders sold to usetaboost
1 of 7 center caps sold
Bill
