getdowngranny
Mr. Fix It
- Jan 8, 2006
The problem is that the little digital tach on the dash and my autometer tach are working intermittently. The auto meter tach is hooked up to the green plug/white wire in the engine compartment. Both gauges work together when they want to. Where should i start chasing the wire down to? Im guessing i should start at the ignition control module, am i right? Where do they both feed from in common to start from there? The rpms work fine on the scanmaster. I took the day off to fix this and would greatly appreciate the help. On another note i had an alarm installed yesterday and since then my knock guage is all out of wack. One of the knock led's stay lit the whole time since the install. Any info?
