Tach signal wire
highboostgn
Where is everyone hooking up their signal wire for their aftermarket tach? Also where should I run the wire through the firewall?
Hook it to the white wire with a green connector behind the alternator. Feed the wire through the hole with the speedometer cable.
Hey, I ran my tach signal off my ECM. I tapped into the spark control signal. I believe it is a white wire. That way you don't have to run it through the firewall. I have had mine connected there since 96 and no issues. Plus it is just as accurate as the other ways.
'87 Turbo T w/E85, 224/224, ported iron heads and intake, 80 lbs injector, TE45A, GEN II, TT and EXTENDER EXTREME G, XP Double pumper and something secret, 86 T-TYPE (Kenne Bell test car) and '11 Tundra Limited Sent from my iPhone using Turbobuick
