Oct 20, 2008 #1 L lazaris Active Member Joined May 25, 2001 Messages 1,497 When converting to a distributor do you loose the stock tach pick up? (Wire with green connector).
Oct 21, 2008 #2 H HighPSI Moderator Staff member Joined May 24, 2001 Messages 5,978 Yes, that is an output of the factory ignition module. You'll need to get it from your ignition box.
