taking out Stagerite T brake??
turbov6joe
Signal 1 J-12
I'm removing my StageRite T brake and returning the VB back to normal operation. I currently have a PMAC/Century shift kit and want to know what kind of trouble am I getting into not having another one of those aluminum plugs you have to pound into the seperator plate? Is it needed? Can I do without it?
When I bought my StageRight from Mallender (think that's his name) I asked him about the hole I had to drill and could it be returned to basically stock if I wanted to do so in the future. He said yes, and the hole could just be left the larger size, that it didn't matter.
Don't beat me up if that's wrong....just passing on info I rec'd from the inventor as I never did return it to stock configuration to test what he said.
What hole is drilled and to what diameter?
ATSG number or other good description?
You can replace the seperator plate with a new GM 8657309 and start fresh.
well well---for once your right! btw got my box---thanks. did you get yours?
It's been a few years, but I don't remember it being more than just removing the parts that came with the kit out of mine.
No, I kept my penis but thanks for asking. I assume by your above statement that you had that sex change operation you always wanted.
Now that have an inney instead of an outey, do you find you play with yourself more than before?
(Although from what Lisa told me, you weren't able to play with "much" when you had your outey.)
:D
