SignUp Now!Originally posted by Razor
What do you have your target AF ratio setup at for drivability? Like idle and cruising?
Originally posted by bruce
Just a reminder, but the leaner you go the more advance you have to run. Lean mixtures are slow burning.
Also, even a WB can be fooled a little by timing. ie running more then you really need, means adding fuel.
I run like ~24d at idle, and no more 38 in cruise. Running like 46 or so in a lean cruise condition, means putting alot of heat into the dome of the piston, and oil. You can wind up with tip-in preignition, and tip-in detonation when implimenting a lean cruise.
Bruce.. your input is invaluable as always..Thanks.
I'll see where the timing is at in respect to AFR in the chart and adjust accordingly.
So is there a time to have spark advance in the 50+ degree range? Or have timing no higher than lets say 38 in cruise or otherwise. Maybe I need to look at some spark tables from some of my favorite chips and see whats going on there.
Thanks..
