TA's S2
HGturboT
HomeGrownPerformanceLV
Does anyone know if TA Perf. is only gonna make a limited amount of there S2 blocks (on center)? I have been saving and i'm a couple of months away from purchasing one.
Thanks, Danny
The TA alum blocks are normally machined for off-center use. If you want an on-center block, you should order it to assure you can get it when needed.
On the previous batch, only 2 on-center blocks were made and these had been pre-sold.
So they will reproduce it , but it will just take a little time? I would like to call them, but with school and work i'm busy mon.-sat. and by the time I get home they close, unless they are open on sun.? And just so i'm correct the on-center is drag only? Thats the one I want.
Thanks, Danny
Neither block would be considered drag only, or street only for that matter.
They will be for whatever the owner has them built to do. Being on center or off center really doesn't have anything to do with it's "funtion" in life.
