I'm having an issue with the Torque Converter clutch on my TR, before the mods move this thread I would like to add it is an ELECTRICAL concern, not mechanical...
When the car is cold and the tcc goes to lock it slips a lot. If I hit the manual lockup switch the converter locks properly. I think the driver (IC) is going out in my ECM. If you use a meter set on current flow, connect one end to terminal f on your DLC and the other to ground what do you read? Trying to find out if the solenoid is bad or computer. I think it is the ecm because when I drive the car as the day progresses it locks more firmly.
What is the current flow of your TCC?
Thanks!
Thanks!
