M moose Member Joined Nov 23, 2003 Sep 11, 2009 #1 Ok, i have searched and found how to make the lockup kick in when i want it to, but what do i have to do or how can i wire it so it won't lockup until i use a manual switch? Can it be wired to be turned off totally until i want it to? Thank's
3 38turbo Member Joined Oct 5, 2008 Sep 12, 2009 #2 if i remember right this is how i did it sorry for the poor diagram 2 min job in ms paint let me know if any more questions if you flip the switch around Up would = normal ecm control center would = off no tcc control down would = locked Attachments tcc control.jpg 26.2 KB · Views: 105
pacecarta LOGGED OUT Staff member Joined Aug 1, 2003 Sep 12, 2009 #3 easier , tcc is controlled by ecm so easy is to put a switch in the wire to pin a7 (tan /blk stripe) at the ecm ,
3 38turbo Member Joined Oct 5, 2008 Sep 12, 2009 #4 yes that works 2 but i didn't want to cut any wires and i hid my switch right next to aldl so brake switch was closer than ecm works either way
M moose Member Joined Nov 23, 2003 Sep 12, 2009 #5 Thanks guys for the info. makes it a lot easier when you guys help since they dont make a GN BOOK FOR DUMMIES !!:biggrin:
