I could find this problem with a search, so here goes.
I replaced my TCC & 4th gear pressure switch last summer because I thought that my TCC was bad(locked & unlocked while driving)
Problem did not go away
I installed a lighted switch to the F terminal to manualy lock the TCC.
When I lock TCC (lighted switch comes on) it will stay locked until I let off and TCC will unlock (light goes out) If I press hard enough on the gas to down shift the TCC will lock again or when going down a hill if I let off to cruise TCC will lock again.
When I'm at cuising speed TCC will not lock (some times it will try to lock) It seems to try to lock the best @ 60, but anything faster and all I get is quick lock/unlock
also my cruise & turn switch not to good.
If the turn/cruise/wiper switch is bad could this cause this problem?
Jim
Jim
