Sep 7, 2003 #1 S snistrgn New Member Joined Jan 29, 2002 Messages 202 I was just wondering if anyone knew what trim are PT&E's Te-44's.
Sep 7, 2003 #2 J John Craig Tech Forum Advisor Joined Jul 9, 2003 Messages 11 TE44 Trim Question The TE44 compressor wheel is T04E 60 Trim, The turbine wheel is T31 Hi-Flow 76 Trim (65mm). John
Sep 8, 2003 #3 T turbo buicks ESADAH!!! Joined Jun 13, 2002 Messages 2,936 is that the same for the TA49 with a .63 exh housing?
Sep 8, 2003 #4 J John Craig Tech Forum Advisor Joined Jul 9, 2003 Messages 11 TE44 and TA49 turbos use the same compressor wheel and turbine wheel.
Sep 23, 2003 #6 4 49-blues Active Member Joined May 30, 2001 Messages 7,628 How big of a compressor wheel can a 44 be built out to? what size turbo and what HP?
Sep 24, 2003 #7 J John Craig Tech Forum Advisor Joined Jul 9, 2003 Messages 11 I don't recommend that you istall a compressor wheel larger than 67mm in a TE44 compressor housing.
