SignUp Now!Don't feel bad about it. I had a T63E and could get it to spool OK but stepped down to a 61 for the same reasons you are. Truth be known, Red isn't spooling his as well as he thinks (1.84 60' and 11.1 with a 70) , MPH is good but the 70 is a 9 second turbo so to use its potential you should be 130 MPH and in the 9's so if you have the MPH you are losing it in the first 1/8 (aka Supra). Red's knows most good running 49 equipped cars run thatOriginally posted by clean86
Red I see what you are saying, and I know he is getting the better end of the deal $ for $ but I only want to get the car to go 11.90 or so. With 009'ss for inj the 63 is flowing a lot of air, more so than the 009's can handle. Also the 60 will be more fun on the street. How you get a 70 to spool with a 2800 is beyond me, but if you can , great. Thx for the info though
Originally posted by Intercooler
Don't feel bad about it. I had a T63E and could get it to spool OK but stepped down to a 61 for the same reasons you are. Truth be known, Red isn't spooling his as well as he thinks (1.84 60' and 11.1 with a 70) , MPH is good but the 70 is a 9 second turbo so to use its potential you should be 130 MPH and in the 9's so if you have the MPH you are losing it in the first 1/8 (aka Supra). Red's knows most good running 49 equipped cars run thatActually 009's are more suited to a 49 which would be even better for your goals but a 60 would be max with those injectors.
