Jan 10, 2005 #1 J jerrad Member Joined Aug 21, 2004 Messages 534 if i put a te44 on my current set up how much time should i expect to knock off?
Jan 10, 2005 #2 G Grandnat Member Joined May 26, 2001 Messages 307 this is a loaded question, however expect a conservative 1/2 a second off of your 1/4 mile ET. I found that 24# was that turbo's sweet spot. results may vary.
Jan 10, 2005 #3 N Nick Micale Tech Advisor Staff member Joined May 26, 2001 Messages 9,208 Maybe nothing if your build/combo does not support it.
Jan 10, 2005 #4 J jerrad Member Joined Aug 21, 2004 Messages 534 does mine not support it? what size turbo would you suggest with 009's and also what size stall
Jan 10, 2005 #5 N Nick Micale Tech Advisor Staff member Joined May 26, 2001 Messages 9,208 To increase power, you need more air/fuel in the cylinders. Stock injectors will give cyls all the fuel needed for mid-12's or so. But a better intercooler will allow more air in easier, and a good downpipe will let it get out better.
Jan 10, 2005 #6 T TurboToy 4PLAYN Joined Nov 13, 2001 Messages 320 i made 440rwhp with 508tq with 25lbs of boost and fastest of 11.80 at 114 with my sig combo. hope that helps turbotoy
