Te60 turbo?
turbotrix2004
Looking to sale the turbo off my Buick I was told it may be a te60 but I'm not sure. The exhaust housing says 63 and compressor housing says 60. There is some side to side play but no in out. I'm going to try and post a video. $300.00
908-966-4211 Mike
Not sure what to ask for it. I was going to try and post a video and go from there or you can pm me an offer
If you are upgrading I may be interested in your converter if your going bigger , Thanks Keith
You may ask Bison or one of the veterans to confirm what it is for sure
Sent from my XT1254 using Tapatalk
fyi
thats not a 60
60 on the cold side is the A/R ratio .60 , same for exhaust side .63 is the A/R ratio of the housing ..stok had .60 cold .63 hot ..but thats not a stock ..its a TE turbo but not a TE60
the exhaust appears its larger than a TE44 but without a measure its not easy to be sure what you have
measure the diameter at the wheel on the hot and cold side and you may be able to determine what it is without pulling it apart to measue the large sides of the wheels
fyi
thats not a 60
It looks like it measures out to 63.5 on the hot side
the 44 would be 2.29 cold side , 2.228 hot side
your measurements dont fall right on any wheel but if your measuring the opening the wheel is smaller
heres a chart for most common turbo wheel dimensions ,
heres pg 2
depending on how close your measuments are... could be a pt61 or a te63
not a TA 63 .. TA would be sxtock appearing with a bolt on inlet bell
if anything its a T63E
That is a gt35 compressor, not sure about the turbine, it has 10 blades, maybe a 62f1? I say it is a 6162
lol now I'm all confused again worst part is I'm getting another turbo to replace this one and I wanted a similar one
