TE63 w/4 bolt .69 hsg. & down pipe
psiedv6
I keep thinking im going to use this but it has been bagged up for years. There is nothing wrong with this turbo, it has about 3000-5000 miles with about 50 passes on it. This turbo worked great and I never went over 20 psi with it.
TE-63 4 bolt .69 on center p-trim hsg. with 4" inlet, big shaft polished compresser hsg.
Down pipe is made for sock headers with a/c and has cut out, may fit other headers but I don't know. It is mild steel and can be jet-hot coated. It has v-band 1/4 way down for easy install.
$900.00 shipped or $850.00 pick up
make offer I don't think I will need this turbo and I can do a package deal with some 55 lbs injectors and maybe HKS wastgate :biggrin:
P.S. it is so shiny and pretty :)
This will need to be rebuilt, I checked it and it is sloppy :confused: I think I will have it rebuilt if someone is interested. It has been sitting for 5 years I think this is the turbo I lost oil pressure because the oil filter blowing off the O-ring at the steet races, (I mean going to church) :biggrin:
ha
koombaya my lord koombaya, hal le lu yah :)
$500.00 takes all shipped as is or $775.00 shipped after rebuild from Innovative Turbo to new condition with your choice of turbine housing 3-bolt .63 .85 or 4-BOLT .69, 81. or .96
