I have been going over my PowerLogger files and noticed that my boost changes with temperature. In one file I was running 18# and the other file I was running 16# with no mechanical changes in boost, the only difference was the intake temps. The 18# run had an intake temp of 55.8 degrees and the 16# run had an intake temp of 67.7 degrees at WOT. Is this normal,if so is there a way to consistently run a certain boost. I also noticed that the higher the intake temp the richer it was. Thanks,ikle
