test pipe
tajohn
hi i just put on my terry huston down pipe with a test pipe can someone tell me how the test pipe connects to the exhaust pipe? the flange on the test pipe is flat and the exhaust is ball shaped.
thanks
Huh??
The test pipe that comes with the THDP replaces the catalytic converter.It slips over the THDP next to the flex connector and then bolts to 4 bolt flat flange that the exhuast hangs on.Where the catalytic use to be.
Maybe your talking inside the engine bay on the turbo?If so,your suppossed to remove the elbow on the turbo and bolt the THDP to that.
HTH
thanks.
i was talking about the lower part but it looks like smoeone befor me welded the 4 bolt flange to the catalytic convertor.
Those Bastards :mad: :mad: :mad:
If you go to a boneyard,you can get the flange from any late third gen fbody..and have that welded onto your exhuast ;)
