Just got the car running after the long winter which I installed my DIY alchy system.
I wanted to see if the alcohol would cause the engine to stumble during idle when I push the test button? Nothing happened.
I filled the reservoir with 50/50 mix denatured/water. I thought the way you can test the system is to idle the engine and inject the alchy and it would cause it to idle rough.
I'm 95% sure the system is working cause I had the up-pipe off and checked it then and it was squirting.
paul
paul
