And then to complicate things, there's the "GAUGE" curve, or the "ATMOSPHERIC" curve. As in "PSIA or PSIG". The Gage curve takes into account atmospheric pressure, using a 15PSI offset. The other does not.
I'm hearing you now.
SignUp Now!And then to complicate things, there's the "GAUGE" curve, or the "ATMOSPHERIC" curve. As in "PSIA or PSIG". The Gage curve takes into account atmospheric pressure, using a 15PSI offset. The other does not.
Those are the wrong sensors. Stay posted. May have a solution to that problem in the next week. FAST are not absolute tmk.Great point, and you are correct, SSI PN (P51-100-A-B-P-5V-000-000) measures absolute pressure. So if I take dash pressure (absolute) and -14.7 (gage) that gets me to dash = 50.3 psi (closer to 44psi mech gauge is reading.
Interesting, thanks for the reply.
Any opinion on experience, which have you deferred to, mech gage or sensor as being most accurate? I would imagine gauge would be +/- 5% worst case. Need to figure out how gage vs absolute correlates to XFI gain/offset. Fast told me that their sensors are absolute as well, but, could not offer any advice on what to do with gain/offset tables to correct other that what turbo nasty and I have done. Surprising that Fast tech was unaware of similar issues (?) but was approving of turbo nasty and I did.
Anyone have similar issues/experience and find a different solution?
Chances are you have the wrong transuducers also. Stay posted for a possible solution in then next week. The oil and fuel through the egr is hard coded at 0 and 100psig. No way to change it and you can't get the voltage range to work with that. The value at 5v would need to be 85.3psig if using an an absolute sensor and since there's no way to change the max value you can't get it linear. Leaving it at 5v max and 1v min it will be off linearly on atmosphere.FWIW on my XFI 2ish volts...Thats around where mine is at to read where the analog for both fuel and oil psi logging
You can't offset with the oil and fuel pressure through the egr. That's the problem. Unless you have 0-100psig transducers. There's no way to currently update the calibration for absolute sensors. Look at the stickers on your transducers for verificationIll need to look at my laptop and see. Its in the sensor calibration not the offset and all that bizzness.
i think you mean 1-5v out sensor
