I'm working on a turbo Buick that someone has installed a TH 350.
I'm going to install the alky kit along with the TT chip. As of now, the ECM doesn't know what gear that trans is in due to no longer having the harness plugged into the original 200 4r. Can I just install some pressure switches into the case of the th 350 and tie them into the proper wires on the original harness? I'm assuming that the wire would need to go to ground when the trans shifted to that particular gear. Also what color wire would go to 2nd, 3rd gear etc? Thanks!
