Th-400 and park/ neutral switch
turboculosis
Pleasant peasant
How do you go about getting the p/n linkage to work. I need to get mine back on to run ME-r. TIA
Alan
what are you using for a shifter? I have my stock one hooked up and working fine, I have a quarter stick and i bought the bracket from hurst that accomodates the rod to the column and it works like factory. even with the stock shifter set up you should be able to make it work.
