TH400 Fluid Fill ???
KWIKR 1
how many quarts did you TH400 guys use to fill a new rebuild TH400 w/deep pan /converter/cooler ? I'm I have about 9 liters (9.5 quarts) in and having a hard time seeing the reading on a braided type dipstick tube . thanks .
__________________
figured it out , used a piece of removable tape on the stick . showed/easier to read the level . 10 L total including 1 L for the TC when installed .
paint the end of the dip stick white the fluid shows up perfectly.
yep , that's what I had done on my 200R4 , worked great .but I was a little concern seeing that the flex tube dip stick is plastic and not metal. not sure how well the paint would stick to it .:)
