SignUp Now!LCA1971 said:Would you run a th400 or a glide? 2900lbs, 274ci(4.060 borex 3.520 stroke), PT-88, 26x8.5 m/t, pro tree 1/8 mile racing! Rear gear will depend on trans!
Thanks,
Chris
The Swede said:With what trans can we get the best ET with?
John Wilde said:Liberty 5 speed, but they are too much money and there is a big learning curve with the clutch! I glide with a neal chance converter sould be fine.
The Swede said:Thank you Sir!
We do know that the Liberty is outstandning but this is empty pocket racing and we was just wondering about PG vs 400 and our thoughts where correct.
Thanks!
Thanks!
turbodragster said:i say a glide all the way and as far as gear for the 1/8 i do not belive in it if you make power and you can leave with boost it shouldnt matter too much i went from a 3.89 gear with a 34.5 in tall tire to a 3.5 gear and seen the same 60 foot and 1/8mile if you hit it hard the torque that little motor will make will compensate for what ever gear within reason
EightSecV6 said:I have a Liberty with the clutch can and Ram dual disc 10" that will cost you less than a race prepped Glide alone. This is the complete setup to fit behind a Buick.
