I have a few th400 parts left over from spare trans build that never happened. I have everything but the planetary set.
BOP case, in perfect condition cleaned and ready to assemble. Will include linkage, snap rings, seals, gaskets etc. $100
8 bolt pump, perfect condition, new gears, teflon bushing and converter feed restricted $50
Center support, fresh seals, aluminum piston $25
Cast direct drum for 34 element sprag, NOS piece with all 4 apply passages, machined for thrust bearing between forward drum (bearing included), aluminum piston, new seals, HD transbrake springs, perfect outer sprag race and spirolock retainer. $200 sprag not included
GM deep trans pan new $50
GM short output and tailhousing with new bearing and seal $50
TH400 adapt-a-case case saver new $50
