TH400 Sale
quickt
Stage 2 Turbo 400 I have 3 units
Manual Reverse Shift Pattern
Pro Trans Brake
Case Prep for Racing
Hytuff Input Shaft
CNC Forward Drum for Exclusive Shaft Retaining System
Intermediate Snap Ring Case Support
Clutch Hub Rollerised
2.48 Rollerised Gear Set
Rear Case Torrington Thrust Bearing
Torsional Main Shaft
Harden Stator Support
H.D. 34 Element Sprag
Tube Shaft Modification (Keeps Direct Drum Parallel Extends HP Capacity of Sprag)
Low Drag Option
Tensioned Sealing Rings
High Energy Expanded Capacity Cutch Packs
ARP Stainless Fasteners
Deep Pan
Hi Flow Filter Assembly
6 Month Warranty
No Core Charge
$1595 + Shipping
transmission special
Thankyou to Lonnie and RichieHighPsi who happens to be a field rep for extreme automatics :D Late night technical support at it's best :eek:
A local car with a large motor and large power adder was having trans problems. As in killing any th400 that was being built by local highperformance transmission shops :( The car made it's maiden voyage last night with the next extreme 400 from extreme automatics. Needless to say the guy is super happy with it. Says he never knew what a real transmission was until now. Thanks Lonnie.
You cannot go wrong with one of these transmissions.
one of the 2 spragless units i sent down a while back??
Lonnie, you have any th350's? If so what is the price? You can PM me the price if you would like. RMVB, T-brake
Thanks for asking but I just dont do TH-350. They just dont hold the power like the 400 and cars dont go any faster with them.
