Thanks bfg DR
BarnesGN
Got me home from the track safe and sound through an awful thunderstorm and gave me my new best times.
1.65-60
8.0-1/8th
85 mph
235/60/15 BFG DR Brand new 21 psi left at 8 lbs
ta-49 18 psi o2 .785 with 2.3* 93 oct
hooker cat back uncapped exhaust
TH DP
009 injectors
ported TB
This is a 7.9x run I was manually shifting it and let stay in 2nd too long 5500 rpm.
Good times Sam... I never was able to pull those 60's with bfg 235's DR. I would not do anything to the rear if your able to get those tires to hook that well.
There where 5-6 GN's at the Farm last night for a local fun cruise happening every 2nd Monday of the month. Free to get in with a small donation going to a good cause. We all had a good time watching Turk lay the smack down on some $40K vette that called him out to race. Other GN's were running anywhere between 8.0-8.6's most of them in street trim.
Mike Banas
87GN
good times Sam. I bet you could drop the pressure down and get even more out of 'em. There's a 7.80 - 7.70 in that combo you have(with better gas). Good luck.
Mike, what times was Turk running?
Turk's son ran the car yesterday and netted 7.34 at 96.8mph with a 1.71 60'. It was Rodney's beater car that Turk had bought recently. The quickest times it pulled was a 7.2 but the weather was indeed cooler that day. It needs some good 28" tires cause it hazes the slicks EVERYTIME it lauches. Turk is currently running some borrowed slicks on 14" rims. I see the car pulling some 7.teens and maybe cut a 7.099999 sec ET but it needs more turbo after that, as its maxed out, IMO.
Mike Banas
87GN
