I would like to know how Red "blueprints" a fuel pump??..Does "blueprinting" mean shimming the pop off valve or
Jap parts in my Buick ? I shudder to think about having to pull a sneak attack on my garage late at night just to carry it in.
What is the cost to swap over to rice fuel instead of race fuel ?
Is the Denso an intank ?
I know a twin pump will do the trick without the overdriving amps.
When I get this fitting done, this will be the no questions asked winner for us. And for $180, the pump is a beast dollar per dollar.
Big question is will it hold up to the excess pressures from high boost? That's what I'm told why Walbros fail.
Probably just have a bad pump, I have excellent luck with Red Armstrong's XP pump not to take anything away from full throttle as they are also a good company to deal with. I also wonder if your problem isn't with the installation.The hose that joins the F/P to the sending unit pipe if it isn't properly secured can leak fuel pressure internally within the tank. Also you cannot use regular fuel hose it must be the high pressure type, To be safe the hose & connections should be rated to with stand 90 PSI.Last year i replaced my stock fuel pump with a walbro 340 and a hot wire.yesterday while running with the hood up i watched the fuel pressure drop off on the gauge below 10psi .i shut the car off,restarted about 1/2 hour later fuel pressure seemed fine untill about 5 to 10 minutes run time,then drops off again.fuel filter is new and pump does not sound good running in tank.i bought the pump and hot wire from full throttle speed.who sells the best in tank pump that lasts longer?
I just installed a Walbro from Racetronix today and other then having to re-wire violet and red (I didn't read the instructions very carefully , the install was a breeze and the product started working 100% as designed.
I pray this pump will last me quite some time though....not interested in doing this procedure again.
I'm working on a custom outlet fitting for the Bosch 044 that will allow us to use it in the tank and fit without hassle (a lot shorter and 5/16 ID). I might have it ready around early Sept when my CNC buddy gets the stainless stock bars in.
You might want to look at your return line! That symtom is very similar to a kinked return line..ask me how I know! lolLast year i replaced my stock fuel pump with a walbro 340 and a hot wire.yesterday while running with the hood up i watched the fuel pressure drop off on the gauge below 10psi .i shut the car off,restarted about 1/2 hour later fuel pressure seemed fine untill about 5 to 10 minutes run time,then drops off again.fuel filter is new and pump does not sound good running in tank.i bought the pump and hot wire from full throttle speed.who sells the best in tank pump that lasts longer?
