the gta rims
The GTA rims are diffrent offsets..........front and rear.
The fronts will fit ( some use spacers but not absolutely necessary ).
Rears MUST use spacers.
Little more specific for ya: Either get ahold of (4) fronts. Or install the GTA fronts on the rear of your Buick (no spacer) and the rears on the front with the 7/16" spacers. This is the way it is done.
When installed this way it looks as if it was meant to be. The fronts have a deeper dish (bigger lip) than the rears, and just plain look right on the back of our cars. The rears have a smaller lip, so they look just right up front.
GOOD CHOICE MAN. you are gonna love those wheels. Whick tires are you gettin to wrap 'em in?
but
but i keep on hereing that spacers are realy bad, they can but to much pressure on teh axle and break the bolts off of the axle???
I don't see why it would be any worse to use .5" thick wheel plus a 7/16" spacer than a 15/16" thick wheel, at least with conical lug nuts.
Those dimensions are just an example. I don't know the actual specs, but do know that my aftermarket aluminum wheels are significantly thicker than the original factory steels.
Tom
Re: but
Not using spacers on the axles, just up front. See configuration explained above.
I don't think 7/16th spacer on the front will be enough to clear the tie rod end with GTA rears. I have IROCs on my wife's 87 NA regal and I have at least 9/16ths worth of spacers with a rear wheel on the front. IROCs and GTA/TTAs have the same offsets. Get four fronts!
I have this configuration on my car. I do believe they are 7/16" spacers, which is just what the guy that I got the wheels from was using on his GN. Is there a better size spacer to use? I dunno. I can tell you that the inner edge of the rim, not the tire, rubs the back of the upper a-arm slightly when turning the wheels as tight as possible. They do not rub the tie rods, etc. and again, the tires do not rub. I have had mine like this for quite sometime with no issues. John's point is valid as far as possibly a different size spacer would be better, and of course 4 fronts would be ideal. However its not that easy to get 4 fronts, but if you can..... do it.
If you wind up using spacers, why not ask a reputable wheel/tire guy and see what he knows. Theres a guy I know around here that has all that info in his head. Hes dealt with just about any wheel/tire configuration you can think of.
7/16" will work, but its close on the tie rod. I have been running spacers on my T-type for over a year now with no problems.
NOTE: I ground on my tie rods just a little bit to get some additional clearance, never had a problem. HTH
Says to me 7/16" won't work without some modification. ;)
I'm using the fronts on the front with no spacers and the rears with 1.5 wheel adapters. I have a 255/50/16 tire on the back and 245/50/16 up front and it looks great.:cool:
They fit without the tie rod modification, trust me, drove like that for over a year and just recently ground on the tie rods while doing Bell Tech Drop Spindles. On stock front suspension it works just fine.
