the PAC alky kit leaking out the up pipe
87GN 98GTP
Andrew
It was originally leaking bad out of the holes in the up pipe of my V1 (i think that the bigger of the 2) so the shop tuning it added some silicone(i think it was) and tightened them down and it helped alot but still leaked a few drips and the dyno runs, any ideas of what to try before getting different nozzles and welding on screw in nozzles
If the washer inside is bent properly to conform to the shape of the pipe itself, you should be able to tighten it down and have it not leak without any sealer. I have a way different setup but I've been running single nozzle for years without any leaks.
Any new updates from the dyno since working on your ignition issues?
unfortunatly not yet, itll be back on the dyno any day now, Im just going with different nozzles that will thread in, then the dyno with the MSD back on it numbers will come
