As some of you recall, I developed a nasty ticking noise a couple of weeks ago. The noise was coming from the bottom end, and I've heard it before. Rod knock. I pulled the motor and #1 rod bearing was hammered, but did not look like it had spun. #5 and 6 were worn at the bottom of the saddle, as well.
I took everything apart and dropped it off at the engine builder a couple weeks ago.
I went down to the engine builder today and found out the rods had not been resized, were not perfectly round, and this had probably caused the problem with #1, 5, and 6 rod bearings. The #1 crank journal was hammered and I will have to have the crank turned 20/20. The rods will get resized. The block will be cleaned and prepped, but the only thing necessary there is a hone. Everything will get double checked.
The builder is also going to do some mild portwork and cleanup on the heads, five angle valve grind, and springs checked, and the heads and intake will be gasket matched.
Unfortunately I forgot to pull the lifters out of the block during disassembly, turned the motor upside down on the stand, and the lifters fell out. I went ahead and purchased a hydraulic Rev 2X cam, 212/218, .462/.470, 110, and new lifters. This replaces the 212/212, .459/.459, 110 that was in it.
The crank and rods will remain stock, the pistons are TRW's, and the center main caps are the billet deals. ARP bolts were used throughout.
Am I missing anything here, guys?
Thanks.
Thanks.
