A lot of people advise not to remove the 2 lower control arm bolts because they're a PITA to line up with the new spring installed. I say do it, but make sure you have the car on stands and 2 jacks to support each side of the control arm. That's the key... with 2 jacks setup in parallel you can raise each side of the control arm slowly and move the jacks into the proper position. As you move the jacks up, you focus on one side to line up. Once you put the one bolt in, you can remove the jack from that side and easily maneuver the other one in position for the other bolt. It took me all of 10 minutes to get both sides lined up and the bolts in.
I do agree that with 1 jack lining up the holes can be a difficult and tedious task.
