hey all,
The locks in the GN havent work since I got the car. Today I wanted to see why, I removed the door panel to fine a cluster f*ck of wires. I had another board member send me a scheimatic of the wiring, but Im no good at reading them. Ive taken some pics in hopes someone can tell me where certain wires go and whats missing in the door. I really appreciate the help. My only other option is to beg another buddy of mine to take his door apart and look at his wiring to mimic it. Im hoping you all can help me fix this so I wont have to do the last option. Here are some pics.
I have the two green wires goin to nothing. There is a plug on the other side of the door that I do have another wire /plug assembly that plugs into it, but then Im lost as to where it goes. The tan & gray wires that go to the door lock actuator were cut, I reconnected them as you see in the pic, I tested the door lock actuator before connecting them to see if the acutator works and it does. After connecting the wires, I plugged in the connector to the door lock switch and it didnt work, so to make sure the plug wasnt bad, I took a jump wire and touched the middle power wire on the plug to the two other wires and the actuator moved up and down, I thought cool . I just need a door lock switch. I shut the door to continue later, door didnt shut all the way and was locked so I went around to the drivers door, opened it up and the theft deterrent system went off, I tried to put the key in both doors to turn it off, no good, key in ignition, no good. I havent at all touched the drivers door yet. Its still intact, only connected door lock actuator and made sure it worked. Now this. Can you please help me figure this out. Thank you so much
