These F***ING Brakes
BADazzBUICK
NO!!...its not a MONTE!!!
Why I havent gone VACCUM yet,I DONT KNOW!!!Well after a year of good brakes I HAD TO MESS WITH THEM.I bought new pads for front and s10 wheel cylinders and soft shoes for back.I also bought a BIONDO line loc,after we installed everything we bleed the brakes.We STRIPPED the bleeder valve for the driver front,all the others bleed fine.I'm replacing the whole caliper tomarrow.Now,the line loc doesnt seem to work,I hope because the driver front wasnt bleed,and when I launch the car on street,1# boost the brake light comes on for a couple seconds.Do you guys think,when I replace caliper and bleed system everything will be fine?Also could someone tell me exactly how to use the line loc,hold the brake, HOLD the button ,release the brake while holding button,burnout,relese button?Is that right? ThanX
Yup. :)
Sounds right to me as far as how to use it. I just had one installed as well & wired into a switch in my ashtray. The brake coming on is normal since when you left off the brake while holding the button the solenoid allows the rear fluid to return and a sensor is picking up on that. My front pads won't hold it so I'll be putting some new ones on the front to see if that helps. Seems like it always works that way.
