things normally seen on an 84 w/ T-link
EyeTalk2Trees
I have a 84Gn with a converted ECM? the part under the coil pack is from an 87. I just got in the new 3.0 version of t-link and I don't have much int he way of information. It shoes rpm, o2, blm, and MAF. is there anything everyone else sees with the same set up? II've looked through the options and haven't found anything else. I have downloaded the 3.2 upgrade and will see what happends tomarrow.
thanks
Since you've converted to an '87 ECM, you need to choose an '87 from the vehicle setup wizard. TurboLink cares about the ECM it's talking to, and if you have changed the ECM, you need to tell it. :)
The '84 ECM only shows a few parameters (as you saw) in Normal mode. The '87 ECM shows a bunch more data.
So... choose an '87 and all should be as you expect.
