Thanks for the input guys. I do know that I am way maxed out on the 60 lb injectors. I don't know how injector duty cycle is calculated. I thought 100% meant they were open half the time and closed half the time. I had a stockish motor last year and broke the # 3 main bearing cap. One thing led to another and I ended up building a great motor without enough fuel system to support it especially after converting to E85. Got tired of buying race gas. I plan on getting the 80 lb injectors and chip from TT as I am not ready to spend the money to upgrade to the FAST and some 120's. Hopefully the 80's will run good up to 20 lb boost and keep me happy for a while. Eric, I will send you that log file. I replaced almost everything on that motor when I rebuilt it last year. New crank sensor, cam sensor, coil pack, CCCI, plugs, wires, but not the MAF. Still have a stock MAF. The wiring harness is old of course but it worked ok until now. I have the Caspers upgraded injector harness but where is a good place to get a new ECM? Thanks again for the input, I really appreciate it.
