Originally posted by gofstbuick
Your warning light system should include the following: 2 LED lights (with built-in resistors, my preference), a fuse holder (5 amp blade, I prefer), connectors, wire (different colors) and solder. You can wire it accordingly. Start with the low alky warning first, connect positive source to one wire of the LED (fuse in between), connect LED black wire to one pole of the level guage and the other pole to ground. When the level drops to complete the circuit it completes ground and turns the warning light on. Now for the Alky on light, use the same positive source for the other LED lamp (you will only be using one fuse for both lamps and the same power source for both lamps). My pressure switch (is between the ground circuit of the relay) completes ground to activate the relay that powers my alky motor. I connected the black wire of the LED to the ground circuit relay wire closest to the relay. When the pressure switch sees the correct pressure (that energizes the relay that turns the alky motor on), the ground circuit is completed to turn the motor on and turn the alky on light on. For you momentary switch (to manually energize the alky motor) connect a wire on the same side of the relay ground as you did for the black alky-on LED and connect it to one side of the switch, the other side of the switch goes to ground. When you push the momentary button, the ground circuit to the relay is completed (bypassing the pressure switch) and the enerzied relay turns the alky pump on and additionally the alky on warning light. I really don't like to bring battery positive in to the cockpit, and would much rather bring wires into the cockpit that completes ground circuits. The power source for the LED come off a ignition pin on the fuse block (an existing B+ or Ignition+ source). I use solderless connectors with built in heat shrink (GM types, at relay and float guage) all other wires are soldered and heat shrinked. No pictures, but draw your wiring diagram out on a piece of paper and remember that electricity basically travels in a circle.
