UR50SLO
The Reaper
- Jun 12, 2001
im currently in the middle of a gn motor swap in my '90 camaro. got the motor mounts from hrpartsn'stuff, i'am very pleased with them,it fell in there. do i need to upgrade my dash or can i get away with the stock gauges? also do i need to notch the frame for dp clearance if i have stock headers on it?
If you use your stock dash make sure you use the stock "Camaro" sending units for the gauges. If it was a V8 car you'll need to do somthing with the Tac feed as it won't read right with V6 pulses being fed to it.
All the gauge wires come from the drivers side bulk head (RH side of booster)
Notching the unibody sure makes it easier for the downpipe. I notched mine alot to fit a 5" downipipe that blends under the car to dual 3" with Ultra flow mufflers.
I'm sure 88Z or I can answer any questions you got.
~Scott
