D
Datsunboy
Guest
Well guys here is a rundown of whats been done recently. Idle is still nasty on my car. It will rarely drop below 1800rpm, and is inconsistent as far as its idle of choice.
New f/p regulator and hotwire... set to 42psi
Cleaned out IAC, checked connector for nasties.
cleaned out the throttle body (just cause i was already there)
did a decent check for vacum leaks, everything LOOKS okay, i sprayed with fi cleaner waiting for idle noise.
IAC reset
attempted TPS reset w voltmeter
The car idles smoothly at low RPMs when i can get it to stay there, but it usually will not.
Ive done that iac and tps adjustment about 15 times and CANT get the thing to be happy at idle and wot.. what gives?
Any thoughts?
Thanks - Evan
IAC reset
Any thoughts?
Thanks - Evan
