OK here we go again...I am still trying to figure out what is causing my code 44 at idle all the time. To recap if you haven't seen my other 3 threads on this...I start the car up...blm number is PEGGED at 150 and doesn't move at all until you start cruising then it's in the 135-145 range
integrator number is always jumping from 135-150 at idle and same during cruise...
o2 mv numbers at idle are always ranging from 120-250 but most of the time it's stuck in the 120-150 range at idle...then it ranges from 300-800 or something during cruise, it's all over the place...
o2 cross counts at idle are ZERO...i never see cross counts during idle...only at cruise and it's in the 20-40 range
IAC number is from 35-40 at idle
TPS number is at .42 at idle
maf sensor is reading 6-5 GPS at idle (ls1 sensor and translator)
down at the bottom it says Learn Cntl - On and it's always on until i start crusing...what does that mean? i reset my computer a long time ago and shouldn't be learning anything now
engine rpm at idle in closed loop ranges from 850-950...
i hooked up a vacuum gauge and tested various vacuum lines...fpr line tests at 22 hg, charcoal canister registers 20-22 hg, pcv valve vacuum line reads 20-22 hg, also ran the car with just the pcv and then ran with pcv and inline check valve, still get same numbers...
i don't think i have vacuum leaks anywhere...i spray carb cleaner around the throttle body and intake area and idle doesn't change...i will double check for exhaust leaks but i replaced my crack ds header with a new poston's header...pass header looks fine and no cracks...crossover looks fine and connected and no leaks...but again i will crawl underneath and check again...
my car has been doing this for 2 years now and i was stock back then...i have changed many many many parts since then and still have the same problem...is this problem internal? i have tried numerous chips, changed to brand new 50 lb fuel injectors, changed o2 sensor NUMEROUS times...running a new GNX sensor right now...doesn't matter what sensor i put in there...all the grounds test ok and i am just lost...
